@James i will try to provide complete guidance from installation to final configuration.
Installation of Automation
Navigate to Setup in left menu > click on Add-ons to access the Add-ons Management page.
On the view add-ons page click the "
Upload add-on" button from the top right corner to add New Addon.
a pop up will apear where you uplaed the
automations.zip file which you can download from client area after purchasing.
Automations Settings and Initial Setup
Enable Automations
In the
Application settings, under the
General tab, set the
Queue driver to the
database. and select
process queues in
Real time from drop down.
Activating Automation and Automation Settings
Under the
Triggers tab, enable
Automation Status.
You will also find the Automation settings select the settings upon your choice.
User Settings
In User side, we have automation settings that contains
Reset Automation Limit: It will take action on the system-paused Automation which is paused due to limit exceed. We have two options
- “Skip” will skip the system-paused automation when the limit is reset
- “Resume” It will resume the system-paused automation when the limit is reset
you will locate these settings by clicking on
profile picture -> user settings -> Automations
i am sure this would help.
