Can't upload images
akauser
Oct 7, 2019
9
It just doesn't upload, it goes goes and then red line and error.
rehan
May 24, 2019
20
5
3
Can you please let me know where are you trying to upload the image? I just tried to reflect it on a test installation and there was no issue in uploading an image in a broadcast. Secondly please also check if size of the image you are trying to upload is not higher than the limit defined at 'upload_max_filesize' in PHP ini settings of your server.
512
91
28
Also make sure that your /storage folder has 777 permissions recursively!
