Changing Mumara Domain
568
110
43
Changing the Mumara domain isn't other than changing the domain name for any web-based application. Follow the steps below to get the domain changed
1. First of all, you need to make sure that the new domain is added to your server
2. Set the new domain to the Mumara physical location or copy the Mumara root folder to the new domain's physical path
So now your domain has been changed at server-level and you want to reflect the new domain in Mumara
3. As your domain has been changed, so you may get a License error sooner or later. Go to your Mumara clientarea, navigate to "My Services" -> click on the License key to manage it and press the "Reissue" button.
4. Now your license key is ready for the new domain. Open Mumara over the new Domain and navigate to Settings -> Licensing.
5. It will automatically fetch the new domain and IP address and will update it in the Mumara database.
6. Make sure you don't forget to update the primary domain in Settings -> Primary domain.
All Done!
Thanks
