If you have recently added a domain in MumaraCampaigns and pressed verified then it means the result has been added to your server cache. If the record wasn't verified in Mumara and you see correct DNS when checked on third-party websites, then don't get panic. Give it some time and it should be resolved once it's out of Mumara server's cache.
PS: This issue mainly occurs when you press the "Confirm" button before adding the records. So always give it a few minutes after adding the records before you press the confirm button.
