cPanel - WHM help
german71
May 24, 2019
4
Hi,
Following Rehan's suggestion, I open this thread asking for anyone to help me with cPanel-WHM, mainly with Apache and MySQL wich are probably misconfigured and causing Mumara to fail.
If interested, please, contact me.
Thank you,
Germán
35
4
8
Dear German,
Can you please explain a little more about the issues being occurred? I'll be open for any help but need to know the issue you are facing.
german71
May 24, 2019
4
Hello, Wasif,
Yes, I explain below the issues found:
#1: Can't change my country in /profile/
No matter what I try, I can't change "Andorra" for "Argentina". The rest of the fields, I saw no aparent issue.
#2: Not fully UTF-8?
Mumara isn't respecting spanish characters in the whole platform. As an example, when I want to see all my contact lists in /list/, I find my name in "Added By" broken: "Germán " instead of "Germán". Same issue occurs in Email Suppression, "Users" column.
Maybe UTF-8 codification is not fully working?
#3: Importing issues in Email Suppresion list
When trying to import contacts to the Global supression list, /suppression-email/, I couldn't import a big csv file. If the file is smaller than 20 MB, you can do it with no problem, but when is bigger, you can't. I tried with one of 69 MB and I couldn't, which is strange considering my upload limit is set to 128mb, far big enough for processing it.
#4: Sorting problems in Email Suppression list
Related to 3, I tried to sort the Email Suppression list acording to "Reference" column, but Mumara give me this error back: "DataTables warning: table id=email_suppression - Ajax error. For more information about this error, please see http://datatables.net/tn/7"
#5: Can't import contacts to a list
I'm trying to import a CSV of 43 MB and I can't. When reaching 58-61%, uploading file starts over from 0%.
My guess is I'm facing the same issue that stated in #3, so fixing this will fix the other or backwards.
***IMPORTANT***
Considering I'm using WHM - cPanel under centOS 7, php 7.1 and MariaDB, it's very likely that isn't Mumara failure but some VPS misconfiguration. I'm pretty sure, in fact. Because of this I'm asking for someone to enter the VPS and check Apache, MySQL, PHP variables, handlers, modules, etc. in the search of this/these misconfigs.
Thank you,
Germán
35
4
8
Dear German,
Ans: I noticed that Jquery is crashing here and not showing you the correct country based on the country code. I have reported this issue and should be fixed in a day.
Ans: I checked in database, I found the list was added by the correct user name i.e Germán. It's not displaying it correctly on the front side. I have reported this issue as well and expecting a resolution by tomorrow.
Ans: I have traced the error and it seems to be as below
[2019-05-28 17:24:56] local.ERROR: ErrorException: Trying to get property of non-object in /home/lageneratriz/public_html/app/Http/Controllers/EmailSuppressionController.php:0
Stack trace:
#0 /home/lageneratriz/public_html/app/Http/Controllers/EmailSuppressionController.php(0): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError(8, 'Trying to get p...', '/home/lagenerat...', 0, Array)
#1 [internal function]: App\Http\Controllers\EmailSuppressionController->getSuppressEmails(Object(Illuminate\Http\Request))
#2 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(55): call_user_func_array(Array, Array)
#3 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(44): Illuminate\Routing\Controller->callAction('getSuppressEmai...', Array)
#4 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(189): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\EmailSuppressionController), 'getSuppressEmai...')
#5 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(144): Illuminate\Routing\Route->runController()
#6 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(653): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request))
#7 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#8 /home/lageneratriz/public_html/app/Http/Middleware/LogoutUsers.php(0): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#9 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): App\Http\Middleware\LogoutUsers->handle(Object(Illuminate\Http\Request), Object(Closure))
#10 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#11 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#12 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#13 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#14 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(65): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#15 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#16 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#17 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#18 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#19 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#20 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#21 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#22 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#23 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#24 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
#25 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#26 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(59): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#27 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
#28 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#29 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(104): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#30 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(655): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#31 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(629): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#32 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(607): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#33 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(268): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#34 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#35 /home/lageneratriz/public_html/app/Http/Middleware/CheckLicense.php(0): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#36 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): App\Http\Middleware\CheckLicense->handle(Object(Illuminate\Http\Request), Object(Closure))
#37 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#38 /home/lageneratriz/public_html/app/Http/Middleware/Locale.php(0): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#39 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): App\Http\Middleware\Locale->handle(Object(Illuminate\Http\Request), Object(Closure))
#40 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#41 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(46): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#42 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(137): Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure))
#43 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#44 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(104): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#45 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(150): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#46 /home/lageneratriz/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(117): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#47 /home/lageneratriz/public_html/index.php(0): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#48 {main}
I have also opened an internal ticket with server staff to get a resolution in a day!
Related to 3, I tried to sort the Email Suppression list according to "Reference" column, but Mumara give me this error back: "DataTables warning: table id=email_suppression - Ajax error. For more information about this error, please see http://datatables.net/tn/7"
Ans: I don't find this issue. Can you check on another browser?
Ans: Import doesn't seem to reflect an issue. by 58-61%, you mean upload or import? However we have a cron in system that runs every 20 minutes to find out any stuck import and if it finds any import was stuck, it resumes again. Better if you can provide me the problematic file to test correctly.
german71
May 24, 2019
4
Dear German,
Stack trace:
#48 {main}
Thank you for your proper help, dear Wasif.
It occurs when uploading. The process starts over and over when reaching this %.
35
4
8
I imported the list for you and it went fine. Also your other issues have been resolved. Thanks
german71
May 24, 2019
4
Thank you, dear Wasif. I didn't check contact import with another list, but I assume it will work great.
...But issues 2, 3 and 4 remain the same; just in case you didn't notice of them. Can you confirm me fixing date for re-trying?
Thank you, as always.
