I got this error from Mumara dashboard:
cURL error 6: Could not resolve host: ipinfo.io; Unknown error (see https://curl.haxx.se/libcurl/c/libcurl-errors.html)
Before error, I have change the innodb-buffer-pool-size from default value to 6G.
Why is 6G? The story is below:
My VPS has 30GB of RAM
I have some problems when I run a campaign with a big list.
I changed the innodb-buffer-pool-size from default to 15G following this post:
community.mumara.com
But then I got a lot of errors, including the error of this question and I cannot access to PowerMTA Managment Console.
So that, I returned the setting back to default --> The errors disappear.
Then I following this article:
dba.stackexchange.com
I run the query in the red square bellow to calculate the optimum innodb-buffer-pool-size
The result is 6G
--> After changing, the error appears again.
Big campaigns are not sent out
I have been using mumara campaigns for about 1 month, go recently everything was great. I have sent about 13kk letters in total. But now the big mailings do not leave mumara. Maybe I have to optimize something?
How large should be mysql innodb_buffer_pool_size?
I have a busy database with solely InnoDB tables which is about 5GB in size. The database runs on a Debian server using SSD disks and I've set max connections = 800 which sometimes saturate and gri...
