Drip Campaign and Delay trigger broadcast does not delay (send instantly)
marakonek
Jan 5, 2023
4
Hi guys,
i am trying to figure how to drip follow-up.
I was trying to use:
1. Drip campaigns after trigger: add to segment and then i drip campaign setup 1. after 5 minutes and 2. after 15 minutes
2. Boradcast wtih Trigger after 5 minutes, and Trigger after 10 minutes.
Both sent immediately and multiple times (same message).
can someone help me figure out why is it happening and how to fix it? Maybe it's below problem regarding database
Example setup: https://prnt.sc/UPUHupSRZ4Cw
Example output (drip sent at the same time): https://prnt.sc/-p48MZ-iBQyD
Also got another issue with database ( think ). After checking "DB check" getting a lot of issues/error". After clicking a button "Fix". Nothing happens.
Error in executing query = ALTER TABLE `active_sessions` CHANGE `id` `id` bigint unsigned NOT NULL AUTO_INCREMENT;
Can this cause issues?
Another question: After creating Drip Campaign after trigger can i see schedule of emails inside drip campaign?
536
96
28
@marakonek you can skip the db issues as it will keep giving the alter queries as the MySQL version mismatches.
Regarding your drips issue, can you tell me the exact criteria of your segment?
marakonek
Jan 5, 2023
4
536
96
28
As you said, you created the trigger based on a segment. Can you provide me with the criteria for the segment? I mean, what filters did you use for the segment? And also, what version of Mumara you are using?
marakonek
Jan 5, 2023
4
Latest version
Segment is created based on email sent criteria.
I have extra idea. I installed mumara on vps ip, not domain. Can it cause issues?
536
96
28
1. You should always use the domain instead of the IP address, as it will not work for the tracking domains.
2. Tell me the exact filters you used for the segment criteria? Based on the email sent or the recipient's engagements? Please share the criteria snapshot so I can try to find the issue.
  • Angry
Reactions: marakonek
marakonek
Jan 5, 2023
4
1. Ok
2. As i wrote above:
LIST - all contacts
SEGMENT - based on criteria EMAIL SENT to LIST OF ALL CONTACTS.
I can't share snapshot right now because i reinstalled mumara
So i had:
LIST FULL OF CONTACT
(TRIGGER)AFTER EMAIL SENT THEY LAND TO:
SEGMENT - CONTACT WHO SENT FROM LUST FULL OF CONTACTS
(TRIGGER) - AFTER CONTACT IS ADDED TO SEGMENT IT STARTS DRIP GROUP INSTANTLY
(DRIP GROUP). Email 1 sent after delay 1h, second 2h, third 3h.
Results?
Test 1 in morning output: https://prnt.sc/7MEmncLAPxsC
Test 2 at night output: https://prnt.sc/G0z1Y6c9-Vkm
Update #2 New test:
List 1 - all contact
Segment 1 - Filter by statistics: https://prnt.sc/SiNex1GBkHE4
Trigger: https://prnt.sc/cFbxLijCusUV https://prnt.sc/Hm7OK-59s9D-
Drip Group: https://prnt.sc/PjLRoNoUIwXm
RESULT:
First follow-up sent after 30 minutes. Should go after 2 hours.
Second follow-up sent after 30 minutes (together with first one). Should go after 4 hours.
Waiting for broadcast trigger delay test after 4 hours.
Update #3
Created NEW segment based on OLDER SEGMENT: https://prnt.sc/cWy4QDPBWp2z
OLDER SEGMENT: https://prnt.sc/n3QoQOrfnsxY
Trigger: https://prnt.sc/GbuskNlTW1JJ https://prnt.sc/x8Ju60S4zUR7
Result: https://prnt.sc/Z6OJyBbcEG62
Result 2 (spamming same message): https://prnt.sc/wC2cQIOE1YQ3
Result 3 (spamming again): https://prnt.sc/2KY1Ww5v3VyJ
WHY NOTHING WORKS IN THIS F****G TOOL?!
536
96
28
@rehan reproduce this case and verify the issue.
536
96
28
Few things you need to keep in mind
  1. You always need to wait for a justified time for the team to reproduce the case, especially on the weekends. Nothing is super quick!
  2. There are hundreds of criteria, and every filter changes how it works. So a technician needs to test it on your installation.
  3. Believe me; this tool isn't designed to understand things within a few hours. It's a massive tool and sometimes requires months to jump to the next level.
  4. I can see that you opened a ticket with support staff 6 hours ago. It should be checked on your installation, and you'll be advised if there is any mistake in the flow.
