Drip Campaigns
Joe
Jun 23, 2022
3
I believe this is a bug when you create or edit and save a drip it just returns you
to step of the drip you are creating or editing. It be better if it took you back to
drip campaigns.
Also, I don't know if this is a bug the drips are sort by the order you made them not
the day or time they go out. So I made 5 each 1 day later. Later I decided to add one
to go out 5 minutes after the instant and it sorted it at the bottom of all the other messages.
i think they should sort by the order they go out. I have attached a pic.
Joe
594
114
43
Dear Joe, the issues have been reported to the dev team. In my case, the sequential sorting seems to be working but I was able to reproduce your issue and it has been reported and fixed already. The new fixes should be packaged with the next update.
