How to add and confirm mail for sending emails?
ILYA
Dec 22, 2021
2
Where can I add a dispatch mail and confirm this mail?
I want to send emails from an address such as [email protected].
I only found how to add and verify my domain.
579
112
43
If you are referring to Mumara ONE.
  1. You add a Sending Domain
  2. You verify it
  3. You create a Contact List and set the owner's email on this sending domain
  4. When you schedule a campaign, Mumara asks you which email to send from
  5. You have an option there to use the sender-info from Contact List or Sending Node or Custom.
  6. If you select contact list, then the set email will be responsible to send the email that you configure in point 3 above
  7. If you use custom, you should again get an option to select domain and email on that domain
  • Like
Reactions: ILYA
