How to dedupe lists?
The functionality to dedupe lists is already available. You can achieve this by clicking on "Remove Duplicate" on the view list page.
Choose the 'dedup list' option from the List Action Menu, and then pick your preferred selection.
To deduplicate lists, or remove duplicate elements, you can use various methods depending on the programming language you are using. Here are some common approaches in Python:
Method 1: Using a Set​
A set automatically removes duplicates because it only stores unique elements.
Method 2: Using a Loop and a Temporary List​
This method maintains the order of elements.
Method 3: Using List Comprehension​
Combines the set approach with list comprehension for a concise solution.
Summary​
  • Set: Fastest but does not maintain order.
  • Loop with Temporary List: Maintains order, slower than a set.
  • List Comprehension with dict.fromkeys(): Maintains order, concise and efficient.
  • Pandas: Best for large datasets, maintains order.
Choose the method that best fits your needs based on the importance of maintaining order and the size of your dataset.
Back
Top
