Mumara Classic Pro Self Hosted Password Reset
peweb
Apr 5, 2022
Hello,
I have just installed classic pro on a Digital Ocean droplet for testing purposes and due to many trials and errors and reinstalls I forgot my login password. I can not use firgot password feature because DO droplet can not send me any emails (port 25 closed, no smtp) so the question is
Where does Mumara store login password? I have access the the CWP7 and should be able to change it, but i can not find it in the database.
Is it possible to change Mumara login passowrd if I have only root access to the server?
Thanks!
512
91
28
You can look into the database table users and edit the password keeping the encryption to SHA1.
