Hi, I have made a test with random smtp, unfortunatelly, its stops every time I try to run it, Is there any way that system will not stop when smtp not work, and for example jump immediatelly to next one? Because this make system very slow. With gmail is that they enable Captcha after some time, and I have to disable it again, I think the solution could be to system not stops when smtp not working just jump to the next nmtp without System Pause
I have set random with batches of 10 and threads 5 , and its stops every time is running. Sequential it work without stopping (from time to time). Let me know if there is anything I fix to use this random, Its impossible to veryfi gmail, as it can happend any minute that gmail can enable captcha again
