The segment isn't a contact list. A segment is a group of contacts among multiple contact lists that qualifies the same/specific criteria. Technically it's wrong if you want to remove duplicates from a segment, as the next question should be, from which list to remove the duplicated contacts? So a better way is to copy or move the segmented contacts to a new list and it will skip/overwrite the duplicates.
