Zeeshanalam
Hi,
I hope I will get response on this trying to reach you people for more then 10 days.
I have followed you this article : https://community.mumara.com/threads/sending-domain-ssl-certificate.277/ and All the required setting are available in the /etc/httpd/conf.d folder.
I was getting this Error.
Muhammad advice me, i quoted, The service `php-fpm` is not installed on your server. You need to run the below command only to install free SSL.
I tried it and installed `php-fpm`. But I am getting the same Error.
See below.
and
Again Muhammad reponsed: If you havnt RUN the this command:
then run this command only, you don't need to run the following command: systemctl restart php-fpm.service.
When I only Run this command: systemctl restart php-fpm.service.
I am getting this ERROR below.
I want to install SSL and I am trying to reach you people for more than 1 weeks but I am not getting ANY response.
Can you please tell me what is WRONG and why I am unable to install SSL even I have ALL your advises.
I hope i will get a proper response that help me to install SSL certificate. Thank you.
See below.
and
