Triggers > when field value is changed > add ability to have 1 more criteria field
zmiller
Oct 11, 2019
40
5
8
Hi,
The newly added trigger criteria for "When a field value is changed" is excellent, but it doesn't quite work for all our use cases. We need ability to add another variable either from custom field or from a list. For example:
When a field value is changed + the value of another field is X
or
When a field value is changed + the subscriber is on list Y
or
When a field value is changed + the subscriber is on segment Z
It doesn't matter which of these is supported, just need to be able to have that 2nd element in defining the criteria for when to fire a trigger. So, we are OK with doing whatever option requires the least amount of development effort (I would venture to guess that is adding list as the option, but not sure...)
How soon might something like this be added to Campaigns+?
Thank you!
marfan
Jul 18, 2019
25
9
3
Thank you for your suggestions. We will soon update you about these changes after discussing them with our CEO.
Thanks
