x-envid
vector_di
Nov 18, 2019
57
3
8
Sometimes I see this error in Mumara Campaigns Dashboard:
"x-envid directive not found in your current PowerMTA configuration. Add the following line in <source 0/0> process-x-envid yes"
But in PowerMTA config this directive is registered.
<source 0/0>
process-x-job yes
process-x-envid yes
hide-message-source yes
</source>
What is it?
594
114
43
You can just mark it as solved.
vector_di
Nov 18, 2019
57
3
8
Thanks for answer,
I understand that I can just mark it as solved.
But this error I see again and again. Is this the solution?
594
114
43
It happens when Mumara is unable to find the directive. Are you sure you are referring to the correct pmta server? As sometimes people have multiple pmta servers and then skip which server Mumara was referring to.
